System Sound Screen Recorder + Fix Problem battery
Please^
1)Add support for recording system sounds
2)Fix Problem batter. BATTERY ON ANDOID9 was discharged (tositdown)
1) The screen has a yellow tint!!!!Very Bad
2) Decreased Brightness!!!!Very Bad
3) The notification indicator does not work
4) Return alway on display
5) Notifications from the application do not come if the application is closed
Answers
  • @niko1988
    1) you can long press the screen recorder icon to show settings for the screen recorder. There you can set "system sounds" as your "sound source".
    2) Sorry, don't really understand that sorry...
    second 1) yellow tint? I haven't noticed that. Maybe you can head into settings -> display -> Colors to optimize it to your preferences.
    second 2) Decreased? In comparison to before Pie or decreasing in what matter? I think also the Pie update made it slightly less bright but not rly sure.
    3) That will be addressed with a future update
    4) ?
    5) This is a known issue for some apps. Better keep them open in the meantime...
  • 2)the battery runs out quickly
    3)I WANT A BRIGHT SCREEN! RETURN BRIGHTNESS, WHITE BRIGHTNESS!!!!!!
    3) the screen is yellow! even if you change
    > display -> Colors to optimize it to your preferences. ------ Does not help!!!!!
    4) alway on display !!!!!!!!!!! seach google
