Home Launcher Problem
I decided to replace the Home Launcher with Nova Launcher and when I press the home button it asked for Accessibility so I added it but later on it asked me again, The accessibility for the Nova Launcher keeps on resetting after awhile.
  • Hey @Lutzkhie,
    Yeah sadly this issue persists since the beginning. The accessibility also resets after a restart. This is apparently stock Android behavior from what I heard... Also when turn off shark space after a gaming session it will ask you for the default launcher no matter how often you pressed always use Nova launcher...
    You can find more info on that matter in this thread: https://forum.blackshark.com/discussion/comment/1282#Comment_1282
  • the accessibility only resets when I press the home button to check the recent apps but if I slide up it doesnt seem to cause problem
